eDRAWINGS integration
OK, what did I do wrong? I installed eDrawings after SW2003 was installed. Now when I go to animate or publish an eDrawing I get a blank screen but I do get the 3d icon. I uninstalled/installed eDrawings several times with no luck. I'm sure I'm overlooking something simple. Thanks.
RE: eDRAWINGS integration
I had similar problem.
SW2003 requires newer version of eDrawing. Get eDrawing 2003 +SP03.
Another thing I would like to mention is that check "Use software OpenGL" of eDrawing Options if the program crushes. There might be a glitch with your video card.
Hey LoveAeris. Thanks for the tips. I'll try them asap.
Hey LoveAeris. I did have the correct version of eDrawings. I checked the 'use software opengl' and that did the trick!! Thanks for your help.
Maybe that will fix the issue I have with eDrawings.  It will not launch from inside SW.  But if I pop up the desktop and launch from there, I can then use it to my heart's content inside SW.  Only two of our 20 or so systems do this (not may people use eDrawings here - I snuck round and tested them all).
It works fine at home on an older graphics card.  All the versions are correct.
3/4 of all the Spam produced goes to Hawaii - shame that's not true of SPAM also.......
