Electrically acutated release mechanism
Dear Sirs,
I am in the process of designing a new product. I am looking for a way to electrically acuate a release mechanism for a sping loaded device from a push button. The small cylindical device 2-3" in length, 1-1.5" in diameter. It will have an internal spring that you will be able to "cock" back an outer plastic cylinder that surrounds a 6" long rod, (.5" diameter). Although unrelated, imagine cocking back a shotgun and using a low voltage signal, causing it to release.
The release mechanism will have to be very small, as the overall length of the device is 2-3"
I had thoughts of a apartment door release buzzer, but it is too large.
If anyone has any thoughts I would greatly appreciate it.
Heath Hummel
Heath Hummel
RE: Electrically acutated release mechanism
<nbucska@pcperipherals.com>
buy a solenoid, make a series circuit with a switch, a solenoid and the battery. there you have it.
I hope Im not off, this is a very simple 101electrical question.
