Center-lines in broken views
Does anyone know what conditions determine whether or not centerlines or any other manually added entities, when added to a view of a drawing, either become deleted or un-attached from the feature to which they were related when the view is broken? It works fine for me in some drawings but not others. Adding breaks to views has always been a very frustrating topic for me.
Thanks for any input!
RE: Center-lines in broken views
I don't know if this is what your after Pegleg.
It depends on which view was active when you added a centerline...etc to a drawing. If you have the Front view Active and add a line to your drawing then that line is attached to that view. If you remove that view that line is removed with it. This works the same for text also.
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
When in doubt, always check the help
