Circular pattern
Circular pattern
Circular pattern
Hello friends,
I am new to using ProE, could anyone explain me in detail how to create a circular pattern...?
Thank you.
Harid
RE: Circular pattern
Maybe not in detail, but the key is that the angular reference you need for your pattern MUST be defined as part of the feature definition. You cannot use an existing reference datum.
In UG, I can choose an existing datum axis or even midpoint of a line and revolve the circular array around that point. So much easier.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
The most important thing to keep in mind when creating radial patterns is that your sketch must be free to rotate about the radial reference.  If the feature to be patterned is dimensioned to a reference that will not allow radial movement (i.e. a datum plane that does not contain an angle, an axis created via two planes, etc.) then the pattern will fail.
Another technique for creating complex radial patterns is to first create an axis that can be radially patterned and then sketch your protrusion/cut so that it is constrained to the first axis.  Then you can create a pattern of the protrusion/cut using the reference pattern function.
Good luck!
