Sheet Format copy
Sheet Format copy
Is there any quick way to copy all data ( customer name, drawing name, material etc) into next sheet after you add it?
We use sometimes multiple sheets and I manually retype all the data.
Thank you.
Andrzej
Thank you.
Andrzej
RE: Sheet Format copy
Save it as a convenient name (I use current D size as the name). When you add a sheet use this file as your current template. Then just use edit sheet to change any data that needs changing.
HTH
Ray
