Car body materials
Car body materials
I need to establish a list of common metals used in automotive body applications. The list does not need to be very in-depth, a few aluminium and steel grades will suffice, e.g. those jaguar and audi use in their latest large executive cars, and commonly used steels in more popular cars, such as ford's focus, crown victoria, etc.
I would welcome any replies.
JD.
JD.
RE: Car body materials
The European manufacturers have favored aluminum alloy 6016 for external panels, while 6111 is more common is the US. Inner panels and sheet for unexposed applications are 5051, 5182, and 6181 in Europe, and 6111, 2008, and 5182 in the US.
You can obtain more information on usage and grades by using the following links:
http://www.steel.org/autosteel/technical_info/index.htm
http://www.cs.virginia.edu/icaa7/trends.pdf
http://www.advancedmanufacturing.com/July01/automotive.htm
In addition to the aluminium grades used, I don't suppose you happen to know the grade of magnesium used by Daimler Crysler in their Maybach engines do you?
A long shot perhaps.......
JD.
http://www.hydromagnesium.com/HITS/OSL02201.NSF/Files/PDF%20brochures/$file/Property%20datasheet.pdf
http://www.hydromagnesium.com/HITS/OSL02201.NSF/Files/brochures_pdf03/$file/Mg_Die_Casting_sec.pdf
http://www.magnesium-industry.com/Library/Highlights/Paper%20of%20the%20Month/papers/Temp%20Behaviour%20AJ52x,%20Heat%20resistant%20magnesium%20alloy%20for%20powertrain%20application.pdf
