Mazak to Amada code
Mazak to Amada code
Mazak to Amada code
Can anyone help me decode the Mazak values P1500 (power)?
Q500 (?) R100  (?) F230 (?) as i have found some cutting data in Mazak format but i am having trouble converting it.
I use Power, frequency, duty, feedrate/speed on an Amada LC1212.
Thanks in advance for any points in the right direction.
RE: Mazak to Amada code
Roy-
P is power in watts
Q is the frequency
R is the duty cycle in %
f is the feed rate
Good luck
