Elect. Conduit in a 2" slab?
Hi all,  Is running a 1" rigid elec. conduit in a 2" slab on steel decking allowed?  This will leave 1" concrete cover only.  Would that be a shrinkage crack problem?  What code should I refer to?  Thanks for your help
RE: Elect. Conduit in a 2" slab?
Not a good idea.  One inch conduit has an O.D. of 1.315.  This leaves only about 5/8 inch of cover.  Plus ACI Section 6.3.5.1 doesn't allow an embedded item larger than one third the slab thickness.
its going too crack, why not run it below the pan
