Radioactive Level Measurement
I want to measure the continous level of HF Acid in a 10m high vessel. I have to use a radioactive level measurement device as they are the only type to be completley non-contact. Can anyone recommend a Radioactive level device?
So far I have only came across the models from Ohmart-Vega, E+H and Berthold
RE: Radioactive Level Measurement
accuracy needed ?
<nbucska@pcperipherals.com>
If vessel is to be constructed, load cells is a good alternative to radio active level transmitters.
rgds,
209larry
You can definately use radioactive level measurement for continuos level measurement .You can use CS-137 source and detector .Since the height is 10 M ,you may have to use 2 sources since there is beam angle limiation .
The vendors indicated by you are very renowned in this field .You may have to furnish the vessel drawing and the layout to the vendors for proper selection of the instrument .
Hope this info helps you .
Thanks.
http://www.synetix.com/services/
Terry D.
I've never had to specify anything in HF service, however I know how nasty it can be.
How about a guided wave radar? Calibration is relatively simple, the wave guide is standard 316 SST (I'm sure they probably make it in more exotic material). I think you can even get an interface off of it if you ever need it again.
I know that Magnetrol makes a good one, I believe it's their "eclipse" series.
- If you think this isn't an option, let me know why so that I know what I should consider should I ever need to specify a level instrument in HF service.
--Igor
