Motor protection
Motor protection
Motor protection
Hi all
I got a 3 phase Doubly fed induction motor 7,5KW,230V/400V,50 Hz, rated rotor current 27A. I used 1 converter to control motor, connected to the Rotor side, start connection. In between motor and converter, I would like to use a Crowbar, and a Switch (0-1-2). The crowbar is for motor protection, using 1 6 pulse rectifier and a thyristor, that is fired by the DC out of the bridge.
The motor will work as a generator that connect to Grid from the Stator side. A DC Motor will drive the shaft.
The converter parametters are: 36KW, rated input current 56A.
Can any one tell me how to chose the right diode bridge and thyristor to protect motor ?
ozmongoose
RE: Motor protection
Question: Is the diode bridge and thyristor for the crowbar 16 pulse rectifier and thyristor? Why 16 pulse? Why not 18 pulse?
Hello
That is not a 16 pulse rectifier. Let say, that is a 6 pulse rectifier. Sorry for that !
Suggestion: It will be better to select a diode bridge manufacturer and have it sized by the tech support. There are various subtleties when it comes to bridges and modular circuits, in general.
