I was wondering if anyone has had e
I was wondering if anyone has had experience with scrubbing Phosphorus Pentoxide fumes from an air stream at elevated temperatures.
I am designing a system where the incoming air is approximately 1100 deg C. By using an air blead as well as evaporative cooling (droplet size of water approx 50 micron) in a Quench Chamber, I estimate that the temperature will drop to around 100 deg C.
The next 2 stages will be a venturi scrubber followed by a zone nozzle polishing scrubber.
The total residence time that particles of Phosphorus Pentoxide (it is in fact a hygroscopicdry solid) will come in contact with water from start to finish will be 9 seconds.
Any comments or suggestions?
Profaic
RE: I was wondering if anyone has had e
Profaic:
since these fumes are typically very small, the venturi may need a considerable pressure drop to do the job.  If the loading is high, the venturi could still be an acceptable choice to take the first cut.  For low-energy polishing of very fine particulate, consider a wet electrostatic precipitator.
PeterAB
