coorelated sub query with group by
I've got an sql statement that ive developed for an application which has been giving back incorrect results for the past few months and ive finally figured out why but cant figure out how to fix it. Anyways, Here it is:
SELECT DATABASEST AS storm_num, MAX(MAXWIND_KT) AS max_wind_speed, DATEDIFF(dd, MIN(CONVERT(datetime, [DATE], 104)), MAX(CONVERT(datetime,
[DATE], 104))) AS duration_days, COUNT(*) AS num_tracks,
(SELECT TOP 1 [NAME]
FROM NHCBestTracks1851To2001$
WHERE NHCBestTracks1851To2001$.DATABASEST = s.DATABASEST
ORDER BY maxwind_kt DESC, [date], hour_utc) AS storm_name,
(SELECT TOP 1 PRESSURE_M
ORDER BY maxwind_kt DESC, [date], hour_utc) AS PRESSURE_M,
(SELECT TOP 1 [date]
ORDER BY maxwind_kt DESC, [date], hour_utc) AS storm_date,
(SELECT TOP 1 hour_utc
ORDER BY maxwind_kt DESC, [date], hour_utc) AS hour_utc,
(SELECT TOP 1 saffirsimp
ORDER BY maxwind_kt DESC, [date], hour_utc) AS ss_scale,
(SELECT TOP 1 yearlystor
ORDER BY maxwind_kt DESC, [date], hour_utc) AS year_storm_num,
(SELECT TOP 1 comment
ORDER BY maxwind_kt DESC, [date], hour_utc) AS comment,
(SELECT TOP 1 AVG(systemspee)
WHERE NHCBestTracks1851To2001$.DATABASEST = s.DATABASEST AND lastpositi = 0) AS avg_trans_speed
FROM dbo.NHCBestTracks1851To2001$ s
WHERE (DATABASEST in (223)) AND (COMMENT in ('*'))
GROUP BY DATABASEST
The info thats comming back is correct :
storm_num, max_wind_speed, duration_days and num_tracks.
the incorrect data are:
storm_name, pressure_M, storm_date, hour_utc, ss_scale, year_storm_num, comment, avg_trans_speed.
The reason is because the Where statement at the end ie "WHERE (DATABASEST = 223) AND (COMMENT = '*')...." does not effect the rows that I just mentioned. I want to figure out a way to have the overall WHERE (the one at the end of entire statment) to effect these results.
The tricky thing is that I cant put the where stuff right up in the coorelated selects (i think thats what they are called) because All that part is hard coded.
See I generate this staement on the fly. that is i add stuff to the end where clause on the fly in an asp page. I could have other things in there at the end like Where commment in ('*','E')...
Note:
There can be other things in the where clause like a date range. (Where date between 11/11/11 and 12/12/12).
This might be totally easy to figure out but IM no sql expert. But I really really need to get this fixed.
I hope someone can figure this out.
Thanks in advance
Dave
GROUP BY DATABASEST
Note:
Thanks in advance
Dave
RE: coorelated sub query with group by
Hope this helps!
BML
If you have some sample data to play w/, this looks like it could be fun to toy around w/. Off the top of my head (though not tested), you should be able to collapse the majority of your selects into a single select since all but the one uses the same where clause:...so instead of:
select id, max(this), min(that),
(select this from this where this.id = b.id) as thisother,
(select that from this where this.id = b.id) as thatother,
(select third from this where this.id = b.id) as thisthird
from maintable b
where etc
group by this, that
you could collapse the sub-selects like this:
select id, max(this), min(that), thisother, thatother, thisthird
from (select this 'thisother', that 'thatother',
third 'thisthird' from this where this) a,
maintable b
where a.id = b.id
and etc
group by this, that
I don't think it will be that bad to nail something down that would be scalable if you have superuser access. I'd imagine this page is on an internal network somewhere, but on the odd chance it's accessible externally, I'd love to see the page to get a feel for what I'm dealing with. (the answer to x+y is much easier when x & y are defined) :)
select DATABASEST storm_num, max(maxwind_kt) max_wind_speed,
datediff(dd, min(convert(datetime, [date],104)), (max(convert(datetime, [date],104)))) duration_days,
count(*) as num_tracks,
(SELECT TOP 1 [NAME] FROM NHCBestTracks1851To2001$ where NHCBestTracks1851To2001$.DATABASEST = s.DATABASEST Order by maxwind_kt desc, [date], hour_utc ) storm_name,
(SELECT TOP 1 PRESSURE_M FROM NHCBestTracks1851To2001$ where NHCBestTracks1851To2001$.DATABASEST = s.DATABASEST Order by maxwind_kt desc, [date], hour_utc ) PRESSURE_M,
(SELECT TOP 1 [date] FROM NHCBestTracks1851To2001$ where NHCBestTracks1851To2001$.DATABASEST = s.DATABASEST Order by maxwind_kt desc, [date], hour_utc ) storm_date,
(SELECT TOP 1 hour_utc FROM NHCBestTracks1851To2001$ where NHCBestTracks1851To2001$.DATABASEST = s.DATABASEST Order by maxwind_kt desc, [date], hour_utc ) hour_utc,
(SELECT TOP 1 saffirsimp FROM NHCBestTracks1851To2001$ where NHCBestTracks1851To2001$.DATABASEST = s.DATABASEST Order by maxwind_kt desc, [date], hour_utc ) ss_scale,
(SELECT TOP 1 yearlystor FROM NHCBestTracks1851To2001$ where NHCBestTracks1851To2001$.DATABASEST = s.DATABASEST Order by maxwind_kt desc, [date], hour_utc ) year_storm_num,
(SELECT TOP 1 comment FROM NHCBestTracks1851To2001$ where NHCBestTracks1851To2001$.DATABASEST = s.DATABASEST Order by maxwind_kt desc, [date], hour_utc ) comment,
(SELECT top 1 round(avg(systemspee),1) FROM NHCBestTracks1851To2001$ where NHCBestTracks1851To2001$.DATABASEST = s.DATABASEST and lastpositi = 0 ) avg_trans_speed
from NHCBestTracks1851To2001$ s
where RECORDNUMB in (32980,22280,19450,11335,6887,5185,2282,25225,30091,24776,4316,32979,21695,21115,19111,15754,8725,8138,5200,3617,17427,7796,6519,6438,30090,25224,14068,11334,28394,19776,17007,24075,21427,15753,14956,8137,5538,31596,25223,8724,7478,507,26917,6518,18113,16305,15669,5201,3618,2590,31595,28937,8399,5537,1478,26836,21709,19451,16304,15670,7479,6439,18112,13576,8215,26835,21116,17160,7797,2591)
and SAFFIRSIMP in ('SS1','SS2','SS3','SS4','SS5','TD','TS')
and COMMENT in ('*')
the first is that i would love to put all the subqueries together but when i do, i get an error that says you can return more than one column in a subquery. this causes me to have to write all this extra crap,
the second is that the final where clause does not effect the subqueries. this means that to make this work the way i want it to i would have to repeat the where clause 8 times. this is very redundant and i wish there was a way around it.
if it was possible to put the subqueries together i would only have to repeat the final where clause once. that would be ideal for me.
any ideas would be greatly appreciated.
thanks
dave benoit
Notice the location of the subqueries in the example from earlier. The subquery set is after the FROM, not part of the SELECT. You can choose as many columns as you want when done this way. You're basically creating a virtual table to join to the main table (in my example called 'a'). Try playing a bit...
Second note: The 'lastpositi = 0' portion in your last subquery, unless that can be included in the WHERE clause of the main statement, that may need to stay a subquery (though I don't see this being a real problem if you're using asp or such to generate the script) [hate not having data in front of me to play w/].
In a rush, so I hope that makes some sense...
Good luck boss.
Dan
