Visual Lisp / Coordinate Transform
Hello Vlisp gurus!
The Players (liberally scattered around the Dwg):
+ A dozen Block Insertions:
All from the same Block Definition containing:
1 rectangle (LwPolyline)
They are scaled and rotated.
+ Some 3000 points
The Game:
Which points are contained in which Block Insertion?
So...
I wish to transform ea. point (ie, its coordinates)
from WCS to the OCS of a Block Insertion.
(From there, a simple Contained-In-Rectangle routine
would take care of the rest).
For (most!) Coordinate Transforms,
Vlisp 2000 provides the Trans function,
with the rather ominous comment:
"For some objects, the OCS is equivalent to the WCS;
for these objects, conversion between OCS and WCS
is a null operation."
Sure enough, my Block Insertion is one of those objects.
Iow, the Trans Function returns me the SAME coordinates
when used like this:
'From' argument = 0 (WCS)
'To' argument = Block Insertion's entity name
One way around this is to code a Coordinate System change
(feeding the Ucs Command the entity name of the Block Insertion),
*then* using Trans function thus:
'To' argument = 1 (Current UCS);
such current UCS being equivalent to our Block Insertion OCS.
Problem is, our scenario is a part of a large application
so 3000 UCS changes is out of the question!
Am I misusing the Trans function?
Or is it such a -nasty emoticons here-?
Thanks.
P.S.:
VBA provides Utility Object / Translate Coordinates Method.
Same deal.
+ Some 3000 points
The Game:
So...
Thanks.
P.S.:
Same deal.
