Max size hole that can be cut into end of airspring (firestone 2m2a)?
I'm trying to design a spring/damping system using a modified firestone 2m2a (little fella) airspring, hooked up to air reservoirs. I need to fill the airspring with liquid and let the liquid act as a piston between the airspring and the actual air reservoirs, so the air-springiness is still there, it just isn't in the spring itself. To get the liquid flowing freely I need a bigger hole in the end of the spring than that provided (its about 2mmdia, I want 10-15mm dia.) I want to drill out this hole but the guy at Firestone reckons that might reduce the rigidity of the plastic endcap so much it would crumple under the force of the clamping ring and ruin the seal. Unfortunately, he doesn't know how big a hole it needs to be before the seal is useless. Has anyone done this and found out already?
RE: Max size hole that can be cut into end of airspring (firestone 2m2a)?
I have a question, though: Why didn't you simply partially fill each bag with liquid (antifreeze?)? I think I've just answered my own question. I'm not familiar with the models, but it sounds like the bags you're using are not large enough to suspend the car without the external air reservoir. But, if you started with the larger bag, it would seem much simpler to partially fill with liquid. I've often thought such a trick would work quite well with a circle track car. With, perhaps, an interconnection between right front and left rear bags and a positive displacement pump in the middle. Or, this same plumbing arrangement could be used at the front of a drag car. (By using a higher rate spring at the right front than at the left, dynamic cancellation of the driveshaft torque can be realized.)
Let us know how your project comes out.
What is the british company modifying air springs you mention? i can find a lot about range rover suspension but i'm not sure that's what you mean...
pat
I don't know how you define later, but back in the '70s I had '65 and '67 Mini Cooper S 1275s that both had the "wet" suspension. It was really easy to change the right height by just pumping in or releasing antifreeze from the two Schrader valves below the rear pan.
These cars had no separate dampers, just the rubber springs and hydro system. They were wired in two circuits, LF to RR and RF to LR, I believe to reduce roll and pitch on bumps.
Eric
They were connected front to back but not side to side. This gave very low pitch resistance, but good roll resistance.
I recently built a boggie trailer for my veteran car useing the 1800 rears, but due to their age they burst under the load, and I am considering my options for stronger bags or springs that might fit the space.
pat
