water treatment closed system
I have a Hot water system with a 304 Stainless exchanger in furnace flue (taking on heat) and a Parker boiler (to make up heat, not sure of exchanger material in this) and a titanium exchanger (give off heat) in a tank with Zinc ammonium chloride in it. All piping is mild steel.
I would like to know what if anything i should add to the system to keep it healthy.
I am not sure if i can or should add anything because of all the different metals in the system.
Thanks,Joe
Thanks,Joe
