EIT exam choice
EIT exam choice
I have not come to the point yet when I am going to take the EIT exam, and have not yet decided if I am going to. I have read a lot of differing opinions on the EIT and PE exams in the forums over the last few months. One thing that I am curious about, as a Senior in Aerospace engineering which exams would I take? There seem to be exams for nearly every other Engineering Degree but not Aerospace. Would this account for my instructors and advisors not talking about the exam, nor encouraging my classmates and myself from taking it? I am just looking for some input and suggestions. After looking at some of the examples, passing the general EIT does not seem to be too difficult if I take it sometime in the next year or right after I graduate. I guess my question is, If as an Aerospace Engineer I was to take the EIT and possibly later the PE exams, which version should I take?
Thanks for ideas and help,
RE: EIT exam choice
It is one of things that becomes much harder to do the longer you wait... (kind of exponentially as you leave school)
As an ex-Aerospace Engineering student turned EE ('69-'70 was a very bad year for Aerospace), I would think that the Mechanical or General sections (for the afternoon session) would be more appropriate -- you might check with your state jourisdiction for what areas might be a prerequisite for your PE (again, what area do you choose?)...
I took both exams prior to the specialization, so I can't give much more advice... other than encourage you to take the EIT soon -- if nothing else, it'll give you the experience and the headaches from such a rigorous exam...
RE: EIT exam choice
RE: EIT exam choice
A few employers outside the CE world do place value on the EIT, if for no other reason than it provides some validation of your overall knowledge.
I've met several AERO's working outside the aerospace industry so you never know how things are going to work out.
Probably ME subjects would be the closest to your academic course of study.
RE: EIT exam choice
Since about 1/3 my graduate ME books (in fluids and thermo) were also required for the Aero MS program, I'd say the closest might be ME with Fluids & Thermo in the afternoon session. I found it hard to believe that folks designing airplanes and space ships couldn't get a PE stamp in their discipline, but I just looked at www.ncees.org and you're right. We're an "industry" that changes slowly.
David
RE: EIT exam choice
Take the EIT as soon as you can. It definately gets harder the longer you wait (a year is a long time!). As for which afternoon section to take, I would suggest you just take the general section. I will say though, I took the chemical eng. specific test in the afternoon and found it to be VERY easy..... I think half of the questions revolved around finding the volumetric flow, pipe area, or fluid velocity given any of the other two (Q=AV).
Good Luck!
jproj
RE: EIT exam choice
I will probably take it either this fall or next spring depending on how my class schedule looks. I think I will end up taking the general, as the mechanical has a few sections not covered in aerospace, specifically HVAC, Fans and pumps, and the material processing section, which together would be a good bit of extra study to learn for the test. Talking to a state board would almost be futile with my history of moving for education. So far I have gone through Highschool in WA, Undergrad in IA, and currently in PA on internship. So only God knows which state I will end up in next. :)
I do wonder though why there is not a test for aerospace engineers along with a PE. Maybe the degree is just too broad to be easily tested, but I will deal with that when I get to it.
Thanks again,
J.G
RE: EIT exam choice
RE: EIT exam choice
The FE/EIT is now a nationally standardized test. Upon passing, and submitting a transcript to the state in which you took the test, and hopefully completed your education, you recieve a form noting your dicsipline and your EIT number. It does not matter if you pass the EIT by taking your specialy or general. I would take general in the afternoon and be done with it.
Good luck,
Try to go to a EIT Review and buy the handbook you get to use during the test so you can flip through it easily.
Daniel
RE: EIT exam choice
I watch several people at my work struggle through studying, etc. at an older age, with kids and wives, etc. I hope I can just pass this thing and it over with ONE TIME. I feel insecure about a lot of the topics because, even three years out of school, all the details fade away.
Good luck to any others going for the EIT or PE.
Tracy
RE: EIT exam choice
