loading macros at startup
SW 2003 sp 3.1
Here is a noob question for sure.
How can you load macros or custom menus etc. when SW starts up?? Whats the procedure? Is there a file like in ACAD?
Thanks for the help.
DG
DG
RE: loading macros at startup
you can specify a macro which should be executed with SolidWorks (a kind of autostart macro) with a commandline option "-m". Edit your shortcut to look like:
E:\Programme\sw2003\sldworks.exe -m "D:\daten\solidworks\macros\mm_24\Gen3DPointCloud.swp"
This will launch SolidWorks and executes the macro. Be sure to enclose the macro filename with " if you have spaces in your filename, but they won't hurt otherwise.
In this macro you can do anythink you want like launching other programs, loading documents and so on.
HTH,
Stefan
unofficial german SolidWorks helppage
http://solidworks.cad.de
Shareware, freeware, tools and macros
http://swtools.cad.de
I believe the suggested way by berlitz executes only once when SW is launched. Is there a way to execute a macro every time when a SW document is opened?
Another way would be to write a macrofeature and place this in your document template. I have never tried this thought ...
HTH,
Stefan
Assume I have a blank part file and load several macros and then save this as a template.
Now if I create a new part using this template, will the macros load automatically?? Maybe this is a way to get it to work for each new part file.
Yes/No/ Maybe so??
DG
The 3 ways I know of doing it are:
1) using the "-m" param
2) Making an addin
3) Making a macro feature. This last one doesnt really get
loaded at startup, but if you code for the regen event, will
basically get called right after the document is loaded.
