SPE Mold Surface finish Spec
I have several drawings of plastic parts that call out "Surface Finish to be SPE #4 minimum" or "Surface Finish to be SPE #5 minimum".  I believe that this is a 1 through 6 scale but I have not been able to locate the spec.  I have been to the SPE web site and contacted several of their members but no luck.  I have found an SPE-SPI mold surface finish spec but it has values that range from A-1 to D-3, no #4 or #5.
I think that there is supposed to be a molded plastic piece that shows the SPE #1 - #6 finishes so that you can make a visual assessment but I am not positive about that.  Any body know where I can get such a thing?
RE: SPE Mold Surface finish Spec
try www.d-m-e.com they sell what your looking for.
Actually, the kit for the old spec is no longer available but they do have a cross reference between the old spec and the new spec.  That was the key piece of info for me.  See this link:
 http://216.91.69.172/DCatalog/pages/N112_frame.htm
I forget the price for DME's (metal) kit but it was over a hundred dollars.  I was able to a plastic one from SPI for $10.  It also came with the cross reference between the specs.  When I called both SPI and SPE no one could tell me what the old numbers meant even though I was forwarded to about 6 different people.
