gas pressure drop equation needed asap please
I am designing a landfill recovery gas line (primarily 50% methane, 50% carbon dioxide gas) which is under vacuum. I am looking for information for gas pressure drop resulting from pipe reducers and sudden expansions. The gas will be pulled through a 24" pipeline, then through a 60" manhole pump station utilized to knockout condensate. I cannot find any equations for gas distribution that deals with this, can anyone help? Not a mechanical engineer, but a civil and if you can provide both the equation, and define units, etc. I would appreciate it as I do not have reference material if you say to utilize a particular equation. Thanks in advance for all help
RE: gas pressure drop equation needed asap please
No one has been able to help you? I have a bead on this problem. What is the vacuum source? How much volume are you talking about? What vacuum level? What is the piping made of in this application. Is the gas saturated? Write back!
SASC
