Use of CO2 in cryogenic grinding
I would be very grateful if someone could provide some info on the use of CO2 in cryogenic grinding. All the literature I've found about cyogenic grinding is focused only in the use of liquid nitrogen. We have performed some tests with our product and it seems that CO2 would be enough to efficiently grind it. Hence I would like some basic data (handling, consumptions, contact mode...). Thank you in advance.
