FAA/JAA engineering authority - DER
Hello folks!
Does anyone here have DER authiority, supported by FAA or JAA? I wish to apply for DER authority (mainly for component repair and engine overhaul), but I don“t know how to start. The only thing I know is that the applicant have to prove knowledge on FAR 145 & 33 regulations, experience in airmotive field (manufacturing or MR&O)... but what else?? And what is the first step?
Thanks for the attention and best regards for all!
Luciano
Luciano
RE: FAA/JAA engineering authority - DER
Grant Wittenborn
Aerospace Engineer
www.darcorp.com
Nigel Waterhouse & Associates
Aeronautical Consulting Engineers
Transport Canada and F.A.A approval & certification of fixed and rotor wing aircraft alterations: Structures, Systems, Powerplants and electrical. FAA PMA, TC PDA.
n_a_waterhouse@hotmail.com
Does the same apply to Company DER application? This was not very clear to me (could not find a clear explanation on FAA page).
Luciano
Mike
http://www.faa.gov/certification/aircraft/av-info/dst/default.htm
Might consider looking for document 8110.37c as a good overview.
Joe
Rascal am I?!....TAKE THAT!!!
--Errol Flynn
If you can get your company to sponsor you, that would be the quickest way to get your DER. Check out the websites as stated above.
Also see from 8100.8B section 307 a.
Then see http://av-info.faa.gov/dst/complete_application_description.htm
There should be a section on the DER Application Package.
If my company would sponsor me to be a DER, I'd do it in a heartbeat, the problem is there are already 2 here, so they don't see the necessity (and neither do I for that matter).
Brian
