Maximum Acceptable Limit
I am interested in finding a table or some information on the maximum acceptable limit of certain chemicals before corrosion. Specifically, I am looking for the limit on H2S, CO2, DO, PH etc...before an alloy could start corroding. I work in a downhole pump manufacturing company, and I need this info almost on a day to day basis.
I appreciate the help.
Thanks.
Thanks.
RE: Maximum Acceptable Limit
www.coleparmer.com/techinfo/chemcomp/icrd2.asp
http://members.aol.com/biocon1/pumchem.htm
These pages have reference information to help choose a pipe material. I'm not sure if its what you are looking for, but I hope it helps.
Jason
http://nace.org/nace/index.asp
They have a handbook series that have thsi type of information in, that is a matrix with Base Materal, Concentration, Temperature and and corrosion rate. A great reference, but pricey.
Corrosion Resistance Tables, Fourth Edition, 3-Volume Set
Edited by P.A. Schweitzer
This new fourth edition is the indispensable guide for materials, corrosion, chemical, industrial, plant, construction, mechanical, maintenance, civil, environmental, metallurgical, plastics, product development, and packaging engineers, as well as upper-level undergraduate and graduate students in these disciplines. Illustrating corrosion as a function of temperature as well as concentration, this fourth edition arranges the nearly 800 tables alphabetically, lists chemical synonyms and trademarks, and furnishes cross references for generic and trade names.
1995 by Marcel Dekker, 7-1/4" x 10-1/4", hardbound, 3,256 pages, tables, and appendices, ISBN 0-8247-9590-3 (Part A), ISBN 0-8247-9591-1 (Part B), ISBN 0-8247-9641-1 (Part C).
Intra-Library loan is the way to go to check them out otherwise be prepared to spend $500 - $600 for this set.
Rich
