deburring and finish not known name
Hi all:
Could you please give me the name of the process used to deburr, round shapes and or polishing using small piece of stones, ceramics or plastic chips, by mean of a vibrating pan and adding some water solution.
I know of a registered trade brand ROTO FINISH,
Which is the generic name for it?
Where I can find more data abbout it ?
Thanks in advance.
Pardal
RE: deburring and finish not known name
Hi Pardal,
I think the answer you are looking for is vibratory bowl finishing.  I'm not sure where you would find data about it... I'm sure someone else already knows!!!  If I find any I will let you know.
I hope this helps.
Jaq
Hello Jaq, yes it is the name, I did a search on google and it give me a lot of info.
Thanks again
Pardal
