Brushless motor as Generator
Gentlemen:
I am looking for In-expensive Brushless motors, 3 phase, two ball bearings to be used as generators.
Step-motors will do as well.
Maybe two phase.
Power : 20 to 100 wats and may be higher.
RPM :Below 3000 , without gears.
Voltage : greater than 12 volts, up to 100 volts,
Cost is critical, volume may be several thousands a year, after 2 years of initial marketing efforts.
Shape is not important, though water tight is desired.
Please send info to hgarciavasquez@yahoo.com and to garciah@flash.net .
I thank you for your assistance.
Nandos
RE: Brushless motor as Generator
You are looking at a very large motor. This type of setup develops moderate voltage with little current in a stock form.
Sounds like a car alternator.  Automotive mas market is going to be cheap. Just remove the diodes and regulator.  Pretty sure these can produce 100V at under 3K rpm.
Thanks a lot for the replies
OPERAHOUSE:
A car alternator is not an alternative, it has slip rings, but if you know of the one without slip rings that are PMG ( Permanent Magnet Generator) please send the info.
Janderson:
Please explain your message and why it is a large motor,
 I have used small 3 phase brushless motors that produced about 100 watts at 2400 RPM that were 5 inch diameter by 4 inch long, unhappily they are not produced anymore.
Nandos
