WOUND ROTOR MOTORS
WOUND ROTOR MOTORS
WOUND ROTOR MOTORS
Hi
I need to replace a 300 hp 60 hz 440 vac wound rotor motor. Does anybody know where i may find a supplier who has used or reconditioned wound rotor motors? Preferably a canadian or usa source.
RE: WOUND ROTOR MOTORS
Suggestion: One way to approach to this is over:
http://www.thomasregister.com
and type Motors: Wound Rotor Induction under Product or Service, which will return 3 companies to begin with
hi jbartos
I tried to get some information from the thomas register site but did not have much sucess. Do you have any other suggestions?
Try this company, I am led to believe they offer an excellent service. A customer of ours here in the UK recently used them to supply a large and very obsolete DC motor.
www.joliet-equipment.com
Hello NEWFIEBOY
Try this site if you like.These people have an extensive inventory of all types of motors and should be able to help you.
They are located in Edmonton,Canada
inquiries@bbelectrical.com
GusD
This company may be a little closer to you!!www.ainsworth.com
