Turbine Housing TIG welding filler material ?
hi everyone.
does anyone know what filler rod to use when welding a cast iron turbocharger housing to a 1018 cold rolled v-band flange? does the housing need to be pre-heated before it is welded?
here's an example
thanks
here's an example
thanks
javier
Custom Turbo Applications
http://www.full-race.com
RE: Turbine Housing TIG welding filler material ?
welding process is TIG
javier
do it right....don't go half-fast
javier
javier
