1.I need reference websites for man
1.I need reference websites for manufacturers of 1/2" NPT threaded pressure relief valves to be used on pipeline ball valves that will relief the body pressure form ASME 150 to ASME 1500 lbs.
2. Also 1/2" NPT pressure relief valve sites to be used up to 10 barg instrument air.  The valves will be used in the air supply to pneumatic actuators and need to conform to ASME standards as well.
Would appreciate some input
RE: 1.I need reference websites for man
Do a google for Farris and Consolidated (Consolidated is now combined with Anderson-Greenwood, another reference I would have given). All can supply you with relief valves for what you need.
I'm not sure what you mean by "body pressure form ASME 150 to ASME 1500 lbs"
1)http://www.dresser.com/internet/businessunits/measurement/subunits/consolidated/products/19000srv.cfm?CFID=214720&CFTOKEN=87319577
19000 Series is 1/2" and larger will do the job.
2)
http://www.andersongreenwood.com/seriesbp.asp
Andersongreenwood has merged with Crosby
Crosby Omni is another good choice.
3)
http://www.hydroseal.com/Products/b.html
Low capacity, low price alternative
good valve for thermal relief applications
J. Alton Cox
President
DeLuca Test Equipment
www.delucatest.com
You could also check with Novamag Italy - a cost effective source.
The Thomas Register can help you source manufacturers for all types of valves.
www.thomasregister.com
