Best place to buy a Replacement motor for ball screw actuator???
I have Thomson performance pak ball screw actuator and the motor went out, I would like ideas on where to buy a replacement motor??? it is a 12 volt system, Your help is appreciated.
Mike
RE: Best place to buy a Replacement motor for ball screw actuator???
Suggestion: Visit
http://www.thomasregister.com
and type Actuators: Ball Screw under Product or Service, which will return 86 companies to approach to
There are a few sites on the web that deal in used and surplus motors. Be aware of the output config. of the motor (gears, shaft features) to save a headache.
Thomson is now owned by Danaher Controls, it that helps.
