www.pressure-drop-calculator.com
Online Pressure Drop Calculator
A small Engineering tool that performs pressure drop calculations for Newtonian fluid flow in round pipes. Related parameters such as Reynolds, fluid velocity, average residence time, shear rate and more are calculated. Animations of the flow in a pipe are added to explain different flow velocity profiles as laminar and turbulent flow.
The sofware and all equations can be downloaded as well.
Freeware.
Freeware.
RE: www.pressure-drop-calculator.com
http://www.carf-engineering.com/
Good luck !
