Execute a shell script from an IUA
Hi all,
Does anyone know if it's possible?
RE: Execute a shell script from an IUA
Yes, it's possible. BUT I'm afraid You need fortran or C to do it.
You need to call fortran/C routine that executes Your shell script.
I have done 4.1.2 that but I don't have that code left..
There was some issues with signals in those days.
Regards TPale
    subroutine sample
c
c ****************************************
c * This subroutine calls a UNIX script  *
c
        call system('ksh $HOME/plot_tif')
c
        return
        end
I hope this helps.
Jackie
Thank you for your answers.
Jackie, I tried to create a load module with your subroutine sample, but I get an error message in IUA function: load module cannot be loaded.
I've been using f77 to compile the .f file, and the "shared" command to generate the load module.
I also set the catia.iuamodule_usr to the right directory.
If you have an idea, let me know
To compile the Fortran program I used Fortran 90, XLF Fortran 5.1.1.1.
