Insert Mode - 2000i¦
Any ideas on how I can fix this.
My current contract is using 2000i². I'm doing castings of water meter bodies......hence loads and loads of rounds.....hence slow regens.
I'm working in insert mode when modifing the 'important' features, but when I drag the insert here arrow in the model tree or redefine a feature, the model regenerates all the way through, thus wasting my clients precious time and money. I'm sure this didn't happen in 2001.
Any ideas on how I can prevent this happening?
Cheers
Hayden
Cheers
Hayden
RE: Insert Mode - 2000i¦
im4cad
Pro Design Services, Inc.
http://www.cadproe.com/pds/home.asp
You might want to try the Regen Info tool which allows you to redefine features as you step through the model and you can jump to specific feature numbers. This might solve the regen problem but I'm not sure.
Give it a try if you haven't already, and let me know if it helps.
Michael
