Out Of Roundness / Ovality ASTM A999-2001 Volume 01.01
I am familiar with Ansi B16.9, where the out of roundness is the sum of absolute values of plus an minus tolerances.
I have a 10 inch pipe (OD 273,05mm) with Wall thickness 4,19mm. Can anyone tell me how to understand the out of roundness of ASTM A999. It says; " The differents in extreme outside readings (ovality) in any cross-section shall not exceed 1,5% of the specified outside diameter".
RE: Out Of Roundness / Ovality ASTM A999-2001 Volume 01.01
