on-line info on sleeve bearing
It looks like this new bearings forum is taking off with lots of knowledgeable folks.
Can anyone suggest any sources of good free on-line information regarding sleeve bearings - general design considerations, installation and maintenance.
Thanks!
Thanks!
RE: on-line info on sleeve bearing
Bearing design basics:
http://www.rmt-inc.com/pc_codes.html
http://www.engr.mun.ca/~katna/index1/sliding_contact.html
http://www.metalwebnews.org/ftp/bearing-book.pdf
more advance:
http://www.engr.mun.ca/~katna/index1/hydrodynamic_bearing.doc
Application notes:
http://www.reliabilitydirect.com/appnotes/jb.html
Classifying bearing failures
http://rpb.waukbearing.com/Technical_Info/Bearing_Damage/Bearing_Damage.pdf
Bearing repair & babbitt alloy types
http://www.babbittrepair.com/information_on_babbitt.htm
http://www.purityalloys.com/Babbitt%20Bearing%20Alloys.HTM
http://www.orion-corp.com/TechnicalLibrary/articles/performance.asp
Vertical thrust bearings
http://www.kingsbury.com/hy_toc.html
Lubrication:
http://www.machinerylubrication.com/Backup/200107/viscosity_table_2.gif
http://www.usace.army.mil/inet/usace-docs/armytm/tm5-692-2/chap6VOL-2.pdf
http://www.usace.army.mil/inet/usace-docs/eng-manuals/em1110-2-1424/c-10.pdf
http://www.usace.army.mil/inet/usace-docs/eng-manuals/em1110-2-1424/c-12.pdf
http://www.usace.army.mil/inet/usace-docs/eng-manuals/em1110-2-1424/c-8.pdf
http://www.joliet-equipment.com/lubrication_tech_tip.htm
http://www.keckoil.com/moc.html
http://www.bently.com/articles/1199white.asp
http://oilanalysis.com/
Just kidding. Great job. You earned a star.
Thanks!
Might be helpful.
