WANTED: equivalent for 2N5160
I want to repair an active shortwave antenna (0.5-30MHz)which has a push-pull driver at its coaxial output stage to drive the cable to the receivers. This driver has a transistor 2N5160 which is a medium power PNP type for rf-purposes. This transistor is blown but this type is discontinued and therefore I look for an equivalent type. Do you have ANY suggestion what other transistor I can use? Just the function is important: gain over frequency, power and noise should be about the same or better, form of case or pinout is NOT important. ANY suggestion welcome, whether US-types, japanese types or something from Europe.
With greetings from Germany
AndreƩ Knott
DD3LY
AndreƩ Knott
DD3LY
RE: WANTED: equivalent for 2N5160
http://kahuna.sdsu.edu/cgi-bin/lwgate/PREMIUM-RX/archives/v01.n090/Subject/article-5.html
http://www.sphere.bc.ca/test/hpparts.html
etc. for more info
<nbucska@pcperipherals.com>
They've got 2N5160 listed...
Try this site. They manufacture obsolete devices.
