I.S. and Power Cabling Segregation
My attempts to find an answer on the net has not been successful. Any assistance would be appreciated.
What I am after is:
What is the minimum distance required between an intrinsically safe/instrumentation cable and 440V AC power cable. Also what should be the minimum spacing between a 6.6kV power cable and the other two?
Thank you.
What I am after is:
Thank you.
RE: I.S. and Power Cabling Segregation
"504.30 Separation of Intrinsically Safe Conductors.
(A) From Nonintrinsically Safe Circuit Conductors.
(1) Open Wiring. Conductors and cables of intrinsically safe circuits not in raceways or cable trays shall be separated at least 50 mm (2 in.) and secured from conductors and cables of any nonintrinsically safe circuits.
Exception: Where either (1) all of the intrinsically safe circuit conductors are in Type MI or MC cables or (2) all of the nonintrinsically safe circuit conductors are in raceways or Type MI or MC cables where the sheathing or cladding is capable of carrying fault current to ground."
Don
