led flasher with normally closed switch
I am using a two transistor led flasher as part of an alarm in my RV. I need to be able to start the flasher by opening a normally closed switch. I have the led flasher working perfectly but I can't figure out how to switch it. I've tried adding another 3906 to switch current to the led but this just makes the led come on solid. I've tried several combinations of resistors with no luck. I'm powering the circuit with 12 volts. I have the complete circuit draw out how I think that it should work for reference. Could email if needed. Thanks.
RE: led flasher with normally closed switch
TTFN
<nbucska@pcperipherals.com>
