two puzzles
two puzzles
1.) You must make a 9A fuse. The only wire you have blows
at 6A.
2.) You must make 2 electrically independent transformers which are one physical unit. 100 % of any active part -- i.e of coil or core -- of one TRAFO MUST be active part of the other TRAFO, too.
Each TRAFO has one primary and one or more secondary.
at 6A.
