Heat xfer -- theoretical question
there are two vertical planes x inches apart. The planes
are infinitesimally thin and the space is filled with air. How does the heat conduction/area depends on the distance ?
RE: Heat xfer -- theoretical question
Also, if the areas of transfer are changing, this compounds and complexes the issue slightly, but I won't go into that. Without going through all the manipulations to get to this point, the resultant formula ends up as:
Q=(Ta-Tb)/Rt
where:
Q=heat flow
Ta=initial temp.
Tb=final temp.
Rt=total of resistances to heat flow
Hope this helps.
saxon
How does the hear transfer across a given air layer -- due
to convection and conduction -- changes with the thickness
of the layer ?
<nbucska@pcperipherals.com>
Saxon stated the answer exactly as it is expounded in theory, except that as you stated, there is no "wall resistance" because you established that the planes are "infinitesimally thin". This is all in keeping with the famous Fourier rate equation that electrical engineers love so dearly.
Now that you have thrown another ingredient into the pot in the shape of covection, you've really "stirred up" the mixture so to speak. Convection effects are unpredictable if left on their own - you can have natural convection or forced convection. To the degree that you can define it, you will establish a relationship with the amount of heat transfer due to that effect. As the air layer is widened (or becomes thicker, the effect of a fixed convection effect becomes less as does the conduction effect - although not at the same rate. The total effect is very complex and requires specific identification in order to quantify the resultant relative results.
Art Montemayor
Spring, TX
The correlation reported by McAdams depends on many factors:
-the ratio L/x, where L is the height of the enclosure and x the gap (or layer) thickness: tests were conducted for a limited range of this ratio
-the Grashof number (that in turn depends on x3)
-for NGr<2x103 there is no convection, and heat transmission is due to conduction only (not accounted for by the equation)
-for 2.1x103<NGr<2x104 the overall heat transfer coefficient between the two walls is inversely proportional to the fourth root of x
-for 2.1x105<NGr<1.1x107 the overall heat transfer coefficient between the two walls is independent on x if the ratio L/x is kept constant
-radiation may be of course of relevance and must be accounted for separately.
This problem was of importance in calculating the heat evacuated through the double walled penetrations of sodium cooled reactors, and I know that in France they calculated also the effect of the space width (the circumference of the penetration) and of the nonuniform wall temperatures by a finite volume approach, as convection loops were found to be forming around the circumference.
prex
http://www.xcalcs.com
Online tools for structural design
The reply from "prex" will best put you on the right track. As you seemed to have known from your second question, the relationship btwn conduction and convection will change with the relative and absolute geometry.
You should consult a graduate level heat transfer text. In the case of natural convection (buoyant flows) it is critical that you regard the limits of any correlations AND the orientation with respect to gravity for such correlations.
The Hewitt et. al. reference I cited also discusses radiant heat transfer in such cases in considerable detail.
Additional outstanding radiant heat transfer refences, useful for complex geometries, are:
(1) McAdams, "Heat Transmission" (McGraw-Hill, 3rd Edition, 1954)
(2) Hottel and Sarofim, "Radiative Transfer" (McGraw-Hill, 1967)
(3) Modest, "Radiative Heat Transfer" (McGraw-Hill, 1993)
nbucska rephrased his original question by asking: "How does the hear transfer across a given air layer -- due to convection and conduction -- changes with the thickness of the layer ?"
I think the question is pretty specific. It limits the response to consider solely convection and conduction - no radiation is to be considered (whether it is important or not). As the title infers, this is theoretical heat transfer, not real life.
Art Montemayor
Spring, TX
