Source for DIN Planet Gears
I am in need of small planet gears of the following nominal specification:
Length - 17 mm
Bore - 13 mm ground Ra 8
Teeth - 24
Rack Profile - DIN 867
Pitch dia. - 19.2 mm
Pressure angle - 20 degrees
Hardness - case hardened to Rc 58
I can provide a drawing. Any leads greatly appreciated.
FTI
Length - 17 mm
Teeth - 24
FTI
RE: Source for DIN Planet Gears
gearguru
