Target Drone Mil-specs
I am looking for military specifications for the design of target drones.  I have been having a problem tracking down any doccuments on this topic.
If anyone has any references to the design standards for UAV's, I'd be most appreciative.
Grant Wittenborn
Aerospace Engineer
www.darcorp.com
RE: Target Drone Mil-specs
Have you tried this site for online MIL specs?
http://assist.daps.dla.mil
I searched for target drone and came up with 2 results.  You should also try searching for UAV and Unmanned Aerial Vehicle.
--Scott
Thanks, Scott
I have not tried this source, but I looked at the DTIC.mil account and everything I found is either from 1950 or restricted.  I just signed up for an account.
I appreciate your help!
Grant Wittenborn
Aerospace Engineer
www.darcorp.com
I can't see that there would be a MIL-SPEC for a gereric UAV.  MIL-SPECS are to ensure conformity in materials, performance, spares etc and except for a spec covering some complete assemblies they are for parts and processes.  You won't get a MIL-SPEC for an aircraft.  There will be a bucket full of specs you might choose to include in the design to make sure you get the same bits every time you order them.
BrianR,
The mil-spec I was looking for is a generic set of specs for an aerial target.  MIL-T-18232 Rev B is the spec on this.
This report is also the "bucket" you refer to, as it contains a ton of other more specific specs for individual components, parts and assemblies.
I did get the application to the ASSIST website, which is where I found this spec.
Grant Wittenborn
Aerospace Engineer
www.darcorp.com
