I created MAcro based fiel in excel
I created MAcro based fiel in excel. I saved this file as 'Excel Add-In' *.xla. When I starts excel my toolbars are visible on the toolbox. It is okey but every time I starts excel the dialog box with message "'Macros may contain viruses ...' Disable/Enable macros" is shown. Is there any way how to set anything to do not showing this dialo box?
Thanks in advance
Vlado
RE: I created MAcro based fiel in excel
From memory there is a check box on this dialog box that says "Always ask before opening documents with macros?"
If you uncheck this box it shouldn't ask you again.
Cheers,
    hojo
Hi Vlado,
What's below is related to XL2000. In other versions, slight changes may be present. Help may be useful to find the actual route.
Click Tools -> Macro -> Security.
The explanations should be satisfactory to decide on a security level.
Good luck,
Engin
