Splined Shaft Vendor
I am currently working on repairing a machine that we have out in our plant and need to purchase splined shaft for the repair.  I will need approximately 1ft of external splined shaft and a section of internal spline to mate to the shaft.  The internal spline fits into a recess of a coupling and is welded to it (1.5" Dia and 0.8" long).  I have looked in Grainger and McMaster-Carr but could not seem to locate what I need in any length.  The following are all of the specs that I have for the external spline
Major Diameter - 1.125"
Minor Diameter - 0.909"
Pitch - 8/16
We are just looking to repair the machine for now to reduce our downtime and keep it runnig for a little longer until we can engineer a better solution to the problem.  Any help would be appreciated
Chad Zeilenga
SealMaster Bearings
