Innovative stabilization techniques for slope cuts on Shale
Slope cuts on shale for road projects in the US/Canadian prairies are characterized by frequent progressive failures. As a result, the final slopes of the cut will be stable at about 8H:1V to 10H:1V, as the residual friction angle of shale is ONLY in the order between 4 to 10 degrees. The shale in this area are generally soft, and appears like "soil", often with slickensided features. Water may usually the cause of initial landslides in such a slope.
Anyone can provide some information on the latest techniques on how to stabilize these slopes without cutting into such a flat slope. Anything such as soil nailing, horizontal drainage system, geofibers, or other ideas which had been implemented for prevention of landslides in this type of slopes ?
Any info would be appreciated. Thanks.
RE: Innovative stabilization techniques for slope cuts on Shale
