Question about eDrawings
Hello All,
Is there a way to send an eDrawings e-mail depicting the Assembly without sending - or allowing to be seen - the Components List?
I have named all of the parts of the assembly with meaningful names, (i.e. part numbers, vendors, etc.) but I don't want those names exposed to the recipient, as it is proprietary information. I have tried everything short of renaming the parts, but I have not been successful.
Any Ideas?
Robert
Any Ideas?
Robert
RE: Question about eDrawings
Save a copy of your entire assembly and rename all of the parts before publishing the eDrawing. Copying an entire assembly can readily be done with SW Explorer or by using "File --> Find references".
You can also copy and rename all components in an assembly using "Save As". On the file save pane (were you type in the new file name) there is a button that is labeled "References". Here is where you can specify new paths and names for all of an assembly's components during a "Save As".
If you are using SWX2003, save the assembly as a part. Then make an eDrawing of that part. Or you could send that part file and they can use the SWX Viewer.
have a great day and good luck.
Jay
One other thing I thought of (but haven't tried) is saving the assembly as a single parasolid file. Then you can import the parasolid back into SolidWorks and all the parts will be in their right place within the assembly. It's possible you may be able to rename the parts as they are imported, or perhaps you could import them into a special directory and rename them in Explorer (if there aren't too many parts).
On second thought, that would be too cumbersome for large assemblies.
Jeff Mowry
DesignHaus Industrial Design
http://www.designhaus-i-d.com
With the assembly that I saved as a part, e-drawings will let me section the assembly (part) and slide the secion plane. All of the components appear to be hollow. The move command, however, is greyed out so it looks like it is not able to be used. I have the Beta 2004 e-drawings but I have not had a chance to play with it. I will keep this thread in mind when I tinker with the new e-drawings.
Cheers,
Jay
