Fire resistant grease
Can anyone help with a UK source for "fire resistant grease"
Thanks in advance
Thanks in advance
RE: Fire resistant grease
Usually the 'big boys' will help specify the right product, and generally e-mail you the data sheets and any relevant health and safety data immediately, and advise you of your local stockist.
I would also recommend KLUBER Lubricant in Halifax, I normaly get sorted by Sandy McClure. If he can't help he wil probably be able to point you in the right direction.
Lester Milton
Telford, Shropshire, UK
whatever the case: bear in mind that increasing the temperature of the grease will cause it to degrade much faster so more frequent relubrication may be needed.
www.prod.exxon.com/exxon_productdata/lube_encyclopedia/fire_resistant_grease.html
"grease formulated with special flame-retardant additives. Unlike a fire-resistant fluid, which will not readily ignite, a fire-resistant grease may burn but will rapidly extinguish itself after the ignition source has been removed."
Hope this clears things up.
Lester Milton
