OSM_D019 : Invalid Data reading
Hi all
Has somebody already seen this error message:
I just want open a CATDrawing and i can't.
Help Please!
Help Please!
RE: OSM_D019 : Invalid Data reading
What level are you using? R10SP3/4??
Check this APAR HD06009 in Tech support website or ask your PLM Support for details.
Kennis Tang.
Can you give me the web adress?
here is the address
https://techsupport.services.ibm.com/engineering/login
You need to register to IBM in order to get fixes.
Regards TPale
Yes, go ahead to register on the PLM Support Website
and find out new things over there ...
OK ... APAR HD06009 is closed and concludes that
the problem is fixed on
V5R10+SP7
V5R11+SP4
V5R12GA
Cheers. Kennis Tang.
I found it!
Regards. Florent PAPINESCHI
