table driven assemblies
So I now know how to drive parts using excel tables.
Where can I find out some good info on how to drive assemblies with a table of parts.
DickG
RE: table driven assemblies
Crap I always forget....
SW 2003 sp3.1
As far as I can tell, it's almost the same as with parts: "Insert --> Design Table"
I tried it on one of my assemblies that has multiple configurations.  Using auto-create, it automatically added all components, mates, and dimensions with configuration-specific states.
I may make you feel, but I can't make you think.
In the help file. It show you how the proper text for filling out tyour DT in assemblies.
click on the Index tab once in the help and type in "design tables" and click on components. Then you will get 3 options. Just pick on the appropriate one that fits your needs to understand how to type the text string in.
Best Regards,
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
When in doubt, always check the help
Yes, you do it the same way as with parts, the mates and components are just features of the assembly like extrudes, revolves, etc... are to parts...
(with the design table open...)
You can double click the Parts to add the Supress State to the design table (DT)...
Double click mates and then double click their dimensions to control them with the DT...
When you double click any feature, it will add the supress state for that feature to the DT... if you don't want to control their state w/ the DT, simply Delete the column...
Tip: Use Distance mates with value of zero (0) instead of Coincident... that way you can control the distance as well as the coincident... instead of having 2 mates with one supressed...
