Duplex Reactor Coupled Generator
I read an embedded generator can be connected in parallel with utility using a duplex reactor to isolate the site load from grid faults. Embedded generator is running continuously ( Heat & power plant).
Can anyone advise how to design this reactor or recommend an expert with experience. Our application is 20kV, 5MW.
RE: Duplex Reactor Coupled Generator
In order to spec the reactor, they will need the following:
-System voltage
-reactance/inductance
-frequency
-fault current (i.e. 1 sec current) after the reactor is inserted
-rated continuous current
-mounting configuration, i.e. single-phase/three-phase stacked
-any space limitations
Their web site is www.ritzusa.com.
