need advice on stuctual setting up a double wide
is it possible to set a double wide on a full basement and taking out the steel beams off the house what would the best choice be as to support the center of the house . should i use i beams or can i install a center support out of lumber with support poles need help on this without it costing me a fortune thanks
RE: need advice on stuctual setting up a double wide
