Solids
Solids
Hello
Is there any way to remake a solid back into a solid after I have exploded it.
RE: Solids
how do You explode a solid?
Lothar
Win NT4.0(SP6),2000(SP3)
AC 2000i(SP2), ADT 3.0(SP3),
AC 2002, ADT 3.3,
AC 2004, ADT 2004
RE: Solids
If this is the case, then I would click the "PROPERTIES" icon and change the thickness to your desired height.
Hope that helps.
arch
RE: Solids
a way to join them again
Yvonne
RE: Solids
I do this, for example, when I've got a slot or bolt circle that I want to fill in.
RE: Solids
BUT- NONE OF THIS HELPS ANSWER YOUR ORIGINAL QUESTION.
No, there's no "Automatic Reconstruct" function for returning the lines to a solid. Sorry.
If you need to extract a shape from a solid, set it aside into its own seperate file, and explode it there, or if you've not done anything else, capture the exploded shape you needed with a copy-clip or cut, and use undo to return to the solid. The copy-clipped or cut shape is still on the clip board. Re-insert it by paste wherever you need it, including another solid you might have opened to receive the shape.
Good Luck.
RE: Solids
Before I explode a solid, or extrude a complicated profile, I save a copy of it to a layer that I have simply called "Backup". This layer stays turned off, and If I need something, I just turn the "Backup" layer on, and reuse whatever I need. Once you explode or erase, and you close ACAD, it is pretty much lost for good. Sometimes I am able to recove an older automatic-save, and pull the parts out that I need.
Flores
RE: Solids
I thought that's what you get ... 2D surfaces.
From her post I though she meant they explode to simple lines like a broken wirframe.
If the 2D suface is correct, I thought you could just extrude the surface or increase the thickness which would mimick the extrude command.
Oh well.
RE: Solids
Yvonne
